Eski 18-04-2008, 00:43   #1
Kayıt Tarihi: 30-03-2008
Şehir: İzmir
Otomobil: Vw Bora Pacific 2004
Mesaj: 58
ACİLL MAGNAT ROCK-800 mü JBL 75.4 mü ? BU GECE KARAR VERMEM LAZIM
Arkadaşlar merhaba 2 takım jbl 6507c ve 1 adet jbl gt5 bağlıycam aracıma jbl 75.4 almayı düşünüyordum(200-220 ytl civarına) fakat bir arkadaş elinde magnat rock-800 anfi olduğunu söyledi 1 ay kullanmış faturalı falan garantisi hala sürüyo değerleri aşağıda veriyorum siz hangisini tavsiye edersiniz magnat nasıl bir markadır bu anfinin ederi nedir herkese şimdiden teşekkürler
Bu arada magnat anfiye de 250 ytl istiyor değermi ?
Magnat The Rock 800 4-channel 1000W Amplifier
[TheRock800] £139.99
Click to enlarge
2 ohm stable Variable low-and high pass 40 - 300 Hz (12 dB per octave) Variable bass boost 0...12 dB at 45 Hz Channel mode selector switch (4/3/2/1 - different models) Low level RCA outputs provide summing signal of channel 1 to 4 for use with a subwoofer amplifier. Low level pass through RCA jacks Bridge- / Tri-mode capability Protection circuit that safeguards against short circuits, DC-offset and overheating Green operation and red protection indication LED
Principle 4-channel Car Hifi amplifier
Max power output into 4 ohms Sinus Burst 2:8, 1kHz, 14,4V
for channels 1-4
Stereo 4x200 Watt
bridge boat 2x500 Watt
RMS power output into 4 ohms DIN 45324, 14,4 V
for channels 1-4
Stereo 4x110 Watt
bridge boat 2x260 Watt
Max.power output into 2 ohms Sinus Burst 2:8, 1kHz, 14,4V
for channels 1-4
Stereo 4x250 Watt
RMS power output into 2 ohms DIN 45324, 14,4 V
for channels 1-4
Stereo 4x140 Watt
Impedance Channel 1 2-8 Ohm
Impedance Channel 2 2-8 Ohm
Impedance Channel 3 2-8 Ohm
Impedance Channel 4 2-8 Ohm
Frequency response 5 Hz - 50 kHz (-3dB)
THD << 0,05%
Übersprechdämpfung > dB
Signal-to-noise ratio >> 100 dB dB
Input sensitivity LOW LEVEL INPUT 0,25V - 4V
Input impedance LOW LEVEL INPUT 20 kOhm Ohm
Variable low pass channel 1 from 40 Hz
Variable low pass channel 1 to 300 Hz
Flankensteilheit Tiefpassfilter 12 dB / Oktave
Variable high pass channel 1 from 40 Hz
Variable high pass channel 1 to 300 Hz
Variable Bass Boost to 12
supply 12V (10-15V)
Flyer17 Çevrimdışı   Alıntı Yaparak Cevapla
Eski 18-04-2008, 09:27   #2
HkN&BhR
ataman_74 - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 10-04-2005
Şehir: İstanbul-Bahçeköy/ Sanayi Mahallesi
Mesaj: 1,379
4*110 RMS gücü var gözüküyor. buda çok iyi bir rakam. Magnat bu arada kaliteli bir markadır
O Şimdi Asker- İzmir Gaziemir Ulş. Okulu Bitti
Afyon İkmal K.lığı Revir. Sıhhıye Er Land Ambls Sof.
ataman_74 Çevrimdışı   Alıntı Yaparak Cevapla
Tüm Zamanlar GMT +3.5. Şu anda saat 11:12.
Sayfa 0.13513899 saniyede (100.00% PHP - 0% MySQL) 7 query kullanılarak yaratıldı.
