Geri   Modifiyem© > Club MdfyM > Otomobil Marka Takımları > Motosiklet
Anket Sonuçlarını Göster: Hangisini Tercih Ederdiniz?
Desmosedici RR 8 88.89%
Hayabusa 1 11.11%
Oy Verenler: 9. Bu ankete oy veremezsiniz
Eski 26-10-2007, 23:58   #1
Miyendis
AirUgrcN - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 07-03-2007
Şehir: Mersin, Çayırova, İstanbul
Otomobil: Yok
Mesaj: 2,982
Arrow Kral Kim?
Kawasaki ZX14 ü de alabilirdik ama farklı dünayların Yıldızları seçilmiş...
http://www.ducati.com/docs_eng/model06/desmosedicirr/flash/d16_2.jpg[/IMG]
http://www.ducati.com/docs_eng/model..._straight.html sesi
Engine
* Type: L-4 cylinder, liquid-cooled, DOHC, Desmodromic, 4 titanium valves per cylinder, gear driven camshafts
* Displacement: 989 cc
* Power: More than 205 HP @ 13,500 rpm*
* Torque: n/a
* Fuel injection: Four 50 mm Magneti Marelli throttle bodies, 12-hole "microjet" with injectors over throttle, manual idle control
* Exhaust: '4-into-2-into-1' vertical exit exhaust/silencer
* Emissions: Euro 3
Transmission
* Gearbox: 6-speed; Cassette type
* Clutch: Dry multi-plate slipper clutch, hydraulically actuated
Vehicle
* Body: Full carbon fiber bodywork
* Frame: Tubular steel trellis hybrid, carbon fiber seat support, aluminum swingarm
* Front Suspension: Ohlins 'FG353' PFF forks USD 43 mm pressurized, with preload, rebound and compression adjustment, TiN coated sliders
* Front Wheel: Marchesini forged and machined magnesium alloy wheels, with 7 spoke design as GP6
* Rear Suspension: Ohlins rear shock, with rebound, low/high speed compression adjustment, and hydraulic preload adjustment
* Rear Wheel: Marchesini forged and machined magnesium alloy wheels, with 7 spoke design as GP6
* Tires: Bridgestone
* Front Brake: Two Brembo radial "monoblock" calipers with four 34 mm pistons; two semi-floating 320 mm x 6 mm discs, with machined flange: the same as GP6 wet race set-up
* Rear Brake: 240 mm fixed disc, fixed caliper with two 34 mm pistons
* Fuel tank: aluminum alloy
* Dry Weight: n/a
* Instruments: New lightweight Corse electronic multifunction dashboard with LCD 'bar' graph tachometer, trip/odometer, anti-theft immobilizer, lap time measurement, oil pressure, fuel reserve, EOBD, clock, air temperature, rev counter
65000 $ usd satis fiyati(satisa sunulduktan 5 saat sonra hepsi satilmis)
Specs
Engine: 1299cc, 4-stroke, four-cylinder, liquid-cooled, DOHC, 16-valve, TSCC,172.6 hp @ 9800 rpm
Bore Stroke: 81.0 x 63.0mm
Compression Ratio: 11.0:1
Fuel System: Keihin/Denso Fuel Injection
Lubrication: Wet sump
Ignition: Digital/Transistorized
Transmission: 6-speed, constant mesh
Final Drive: #530 chain
Overall Length: 2140mm (84.3 in.)
Overall Width: 740mm (29.1 in.)
Overall Height: 1155mm (45.5 in.)
Seat Height: 805mm (31.7 in.)
Ground Clearance: 120mm (4.7 in.)
Wheelbase: 1485mm (58.5 in.)
Dry Weight: 217kg (478 lbs.) 218kg (480 lbs.) CA. model
Suspension Front: Inverted telescopic, coil spring, fully adjustable spring preload, 14-way adjustable rebound damping and 13-way adjustable compression damping
Suspension Rear: Link-type, gas/oil damped, fully adjustable spring preload, 22-way adjustable compression & rebound damping
Brakes Front: Dual hydraulic disc
Brakes Rear: Single hydraulic disc
Tires Front: 120/70-ZR-17
Tires Rear: 190/50-ZR-17
Fuel Tank Capacity: 21 liter (5.5 gal.) 19.0 liter (5.0 gal.) CA. model
11000 $ usd satis fiyati
ALINTIDIR.
AirUgrcN Çevrimdışı   Alıntı Yaparak Cevapla
Eski 27-10-2007, 13:23   #2
membran member
CrKN - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 24-06-2006
Şehir: darfur
Otomobil: 4 tekerli kara taşıtı
Mesaj: 19,896
Re: Kral Kim?
Hayabusa'yı bu karsılastırmaya koyan her kimse sadece Hayabusa'yı ezmek için koymuş. Bakalım kaç oy alıcak...
Close your eyes.. Let me kiss you..
Mesajı son düzenleyen CrKN : 22-07-2008 - 18:21
CrKN Çevrimdışı   Alıntı Yaparak Cevapla
Eski 27-10-2007, 13:38   #3
Miyendis
Otomobil: Yok
Mesaj: 2,982
Re: Kral Kim?
Desmosedici RR daki sesi duyunca kafayı yiyorum doğrusu.
RR demişken Kaptan nerde?
Eski 27-10-2007, 13:43   #4
AOVGFG
Otomobil: uçar gider
Mesaj: 7,318
Re: Kral Kim?
Ducati'ye tercih edeceğim motor olsa olsa Agusta olur
Hayabusa da neymiş
Eski 27-10-2007, 13:55   #5
Mesaj: 33,559
Re: Kral Kim?
Hakkaten yani..
Desmo'yu Agusta 312R ile karışlaştırabiliriz anca, F4 1000 bile feci yavan kalır yanında.
Onların bir gömlek altı ezikler R1, 1000RR falan olur.
Hayabusa hiç barınamaz burada, pis dayak yer
Eski 27-10-2007, 14:00   #6
membran member
Şehir: darfur
Mesaj: 19,896
Re: Kral Kim?
Desmo sport touring mi supersport mu ? Hani desmoyla hayabusa o yuzden karsılastırılmıstır falan
Eski 27-10-2007, 14:05   #7
Miyendis
Otomobil: Yok
Mesaj: 2,982
Re: Kral Kim?
Valla Desmo direk Moto Gp yarışcısı benim bildiğim...
Eski 27-10-2007, 14:06   #8
Mesaj: 33,559
Re: Kral Kim?
Desmo ultra supersport abi.
Alakası yok yani busa ile
Eski 27-10-2007, 14:43   #9
membran member
Şehir: darfur
Mesaj: 19,896
Re: Kral Kim?
eee ne ... yemeye karsılastırma yapılıyo bunlar anlamıyorum nerden alıntı bu
ayrıca hayabusa tamam cok guzel bi motosiklet beğeniyorum ben ama harbiden cok abartılıyo yaw.. bilen bilmeyen etkileniyo sonra.. ertan abi de bu yüzden tiksiniyo sanırım hayabusadan
Eski 27-10-2007, 16:27   #10
Miyendis
Otomobil: Yok
Mesaj: 2,982
Re: Kral Kim?
Hayabusa garip bir araç.
Turbo+blow off lusu bilem var.
Belkide güçlü denilince; motor hacminden ve gücünden dolayı insanın aklına ilk gelen motorsiklet olduğu için Karşılaştırmaya koymuşlardır...
Tüm Zamanlar GMT +3.5. Şu anda saat 16:23.
Sayfa 0.77129889 saniyede (100.00% PHP - 0% MySQL) 8 query kullanılarak yaratıldı.
