| www.otvyehayir.com Kayıt Tarihi: 24-05-2006 Şehir: İstanbul Otomobil: CBR1000RR Vectra Elegance
Mesaj: 40,440
| Can-** Spider
Bu gün kızıntoprakta bir araç kurcaladım paylaşmak istedim sizinle de. Fiyatı 36 500 euro.2000 adetle sınırlı üretim, kurcaladığım araç 330 uncu üretilen araç ![]() / Engine / Manufacturer................................BRP-Rotax Type.............................................. 990 V-Twin Displacement...............................60.90 in 3 (998cc) Bore.............................................. 3.82 in (97 mm) Stroke...........................................2 .68 in (68 mm) Cylinder........................................2 Valves per cylinder.......................DOHC 4 Max output...................................106 hp @ 8500 rpm (79 kW @ 8500 rpm) Max torque...................................77 lb-ft @ 6250 rpm (104.3 Nm @ 6250 rpm) Compression ratio........................10.8:1 Ignition type.................................Electronic ignition with dual output coil Lubrication....................................5W4 0 BRP synthetic oil Exhaust system.............................2-into-1 with catalytic converter Cooling.........................................Li quid cooled Injection........................................M ulti-point EFI with 57 mm diameter throttle bodies / Drive Train / Gear box......................................Sequentia l Manual 5-Speed (SM5) with transmission-based reverse Optional gear box........................Sequential Electronic 5-Speed (SE5) with transmission-based reverse Final drive.....................................28/79 ratio final drive with Carbon-reinforced drive belt Clutch...........................................W et, multi-plate, manual operation through a hydraulic piston / Electric Equipment / Magneto.......................................500 Watt Starter........................................... Electric Battery..........................................D ry Cell, 12V, 21 Amp / Geometry / Front suspension..........................Double A-Arm with anti-roll bar Steering........................................DP S (Dynamic Power Steering)Front suspension travel................5.67 in (144 mm) with adjustable cam Rear suspension...........................Swing-arm with monoshock Rear suspension travel.................5.71 in (145 mm) with adjustable cam Chassis type.................................SST Spyder (Surrounding Spar Technology) Mesajı son düzenleyen binRR : 04-05-2008 - 05:02 |
Mesaj: 40,440
Tires & Wheels / Front tire.......................................KR21 165/65R14 Front nominal pressure................13-17 psi (89-117 kPa) Rear tire........................................KR21 225/50R15 Rear nominal pressure..................13-17 psi (89-117 kPa) Wheel size, front...........................Aluminum 14x5 (355x127) Wheel size, rear............................Aluminum 15x7 (381x178) / Brakes / Type..........................................Foot-actuated, fully integrated hydraulic 3-wheel braking system Front braking system................4 piston calipers with 10.2 in x 0.25 in (260 mm x 6 mm) discs Rear braking system.................Single-piston caliper with 10.2 in x 0.25 in (260 mm x 6 mm) disc EBD..........................................Elect ronic Brake Distribution ABS...........................................Anti-lock Braking System Parking brake...........................Mechanical, foot actuated to the rear caliper / Safety & Security / VSS...........................................Vehi cle Stability System ABS...........................................Anti-lock Braking System TCS...........................................Trac tion Control System SCS...........................................Stab ility Control System with Roll-Over Mitigation DPS...........................................Dyna mic Power Steering DESS.........................................Digit ally Encoded Security System Mesajı son düzenleyen binRR : 04-05-2008 - 04:54 |
Mesaj: 40,440
/ Vehicle Dimensions & Weights / Dry vehicle weight....................697 lbs (316 kg) Front storage capacity.............2,685 in3 (44 l) Front max load capacity...........30 lbs (15.9 kg) Total vehicle load allowed........440 lbs (200 kg) Fuel capacity............................7.13 US gal (27 l) Oil capacity..............................1.19 US gal (4.5 l) Coolant capacity......................0.85 US gal (3.2 l) GVWR.......................................1,188 lbs (540 kg) Ground clearance.....................4.5 in (115 mm) Vehicle overall height...............45.1 in (1,145 mm) Vehicle overall length...............105 in (2,667 mm) Vehicle overall width................59.3 in (1,506 mm) Seat (top) height.......................29 in (737 mm) Wheel base..............................68 in (1,727 mm) Wheel track, front.....................51.5 in (1,308 mm) Type of gas...............................Unleaded, 87 octane minimum / Features & Main Options / Color choices...........................Full Moon Millennium Yellow Instrumentation........................Dual analog and LCD w/speedometer, tachometer, electric fuel gauge, daily trip (A & B) meters, engine temperature, ambient temperature and gear position indicator. Information displayed in either metric or US Standards Main options............................Fog lights, xenon lights, mono seat cover, racing exhaust pipe, travel bags, cargo liner, passenger backrest, low Mesajı son düzenleyen binRR : 04-05-2008 - 04:54 |
Mesaj: 40,440
| Mesajı son düzenleyen binRR : 04-05-2008 - 04:57 |
Mesaj: 40,440
| Mesajı son düzenleyen binRR : 04-05-2008 - 05:00 |
Mesaj: 40,440
Mesaj: 40,440
| Mesajı son düzenleyen binRR : 04-05-2008 - 05:03 |
| **** Kayıt Tarihi: 08-03-2007 Yaş: 24
Mesaj: 9,431
330. demiştin |
Mesaj: 40,440
Mesaj: 9,431
benim araba gibi bu ya. satıp bundan alıyım |
