Geri   Modifiyem© > Club MdfyM > Otomobil Marka Takımları > Motosiklet
Eski 12-09-2007, 13:11   #1
Mesaj: 33,559
2008 Kawasaki ZX-10R
Factory Superbike Talent in a Street Savvy Performer
For the 2008 NINJA® ZX™-10R, Kawasaki engineers aimed for an ideal superbike with engine and chassis performance capable of satisfying professional racers, combined with top-notch streetbike qualities for mainstream riders. It’s a delicate balance, but these aren’t your average engineers. They’ve been directly involved in the development of every 600 and 1000cc supersport machine since the 2003 Ninja ZX-6R, plus Kawasaki’s factory Superbike racing efforts, so they have the know-how to deliver the goods.
The result is an exceptionally communicative machine that provides the clean two-way rider and machine dialog demanded by professional racers. Placing the ZX-10R in the racing crucible and applying lessons from that unforgiving environment resulted in an ideal balance to satisfy the most demanding of riders.
Kawasaki engineers relied on the assistance of a professional Superbike rider to push the new ZX-10R’s engine and frame components to the limits in actual competition. Parts that met with the racer’s approval were then tried on the production test bike, tweaked, retested on the race bike and adjusted again. This process was repeated throughout the development cycle for the all-new 2008 Ninja ZX-10R.
2008 Kawasaki Ninja® ZX™-10R Specifications
Engine:
Four-stroke, liquid-cooled, DOHC, four valves per cylinder, inline-four
Displacement: 998cc
Bore x stroke: 76.0 x 55.0mm
Maximum torque: TBD
Compression ratio: 12.7:1
Fuel injection: DFI with 43mm Keihin throttle bodies with oval sub-throttles, two injectors per cylinder
Ignition: TBD
Transmission: TBD
Final drive: TBD
Rake / trail: TBD
Front tire: 120/70 ZR17
Rear tire: 190/55 ZR17
Wheelbase: TBD
Front suspension / wheel travel: 43mm inverted fork with DLC coating, adjustable rebound and compression damping, spring preload adjustability and top-out springs / TBD
Rear suspension / wheel travel: Bottom-Link Uni-Trak® with top-out spring, stepless, dual-range (high/low-speed) compression damping, stepless rebound damping, fully adjustable spring preload / TBD
Front brakes: Dual semi-floating 310 mm petal discs with dual four-piston radial-mount calipers
Rear brakes: Single 220mm petal disc with single-piston aluminum caliper
Overall length: TBD
Overall width: TBD
Overall height: TBD
Seat height: TBD
Dry weight: TBD
Fuel capacity: TBD
Color choices: TBD
MSRP standard / Special Edition: TBD / TBD
Warranty: TBD
*Specifications are subject to change.
Kaynak: Bikeland.org & Kawasaki Motors Corp., U.S.A.
Mesajı son düzenleyen thekillingroad : 12-09-2007 - 13:13
Eski 12-09-2007, 13:12   #2
Mesaj: 33,559
Re: 2008 Kawasaki ZX-10R
Eski 12-09-2007, 13:16   #3
Gerçekçi OL imkansızıİSTE
atomkarınca - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 08-07-2005
Yaş: 37
Otomobil: yok
Mesaj: 24,477
Blog Kayıtları: 2
egzoz ve aynalar hoş durmuş
atomkarınca Çevrimdışı   Alıntı Yaparak Cevapla
Eski 12-09-2007, 13:16   #4
Üye
SwiTch - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 25-12-2004
Mesaj: 4,858
ne -killer ismini sen koy
SwiTch Çevrimdışı   Alıntı Yaparak Cevapla
Eski 12-09-2007, 13:17   #5
Miyendis
AirUgrcN - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 07-03-2007
Şehir: Mersin, Çayırova, İstanbul
Otomobil: Yok
Mesaj: 2,982
Biraz tombul mu olmuş ne? Eksoz pek hoşuma gitmedi bi de. Onun dışında Yeşil Ninjalara Çocukluğumdan beri hastayım zaten. Teşekkürler Ozan abi.
AirUgrcN Çevrimdışı   Alıntı Yaparak Cevapla
Eski 12-09-2007, 13:20   #6
naturally aspirated only
dragsteer1982 - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 26-01-2005
Otomobil: SaxoVTS-Pontiac-Uno-Damas
Mesaj: 4,056
Bu yaramaz bizim motorculara baksanıza plakalık war bizimkiler plakıyı arka tekerleğin üstüne takıyorya
dragsteer1982 Çevrimdışı   Alıntı Yaparak Cevapla
Eski 12-09-2007, 13:29   #7
AOVGFG
Otomobil: uçar gider
Mesaj: 7,318
eksoz olmamış
ayna güzel olmuş ama çalıntı sanki
fren diskine bak, metal yüzeyden çok hava kanalı var
Eski 12-09-2007, 13:31   #8
Mesaj: 33,559
Ayna çalıntı, egzost berbat.
Delikli diskler bir garip zaten.. Tamam soğutuyorsun da.. sürtünecek yüzey kalmıyor resmen...
Eski 12-09-2007, 13:32   #9
Yaş: 37
Otomobil: yok
Mesaj: 24,477
Blog Kayıtları: 2
Orjinal Mesaj Sahibi thekillingroad Mesajı Göster
kasıtlı vurgulamıştım ayna ve egzostu
Eski 12-09-2007, 13:38   #10
Miyendis
Otomobil: Yok
Mesaj: 2,982
Kesinlikle eski Ninjalar daha haşin, saldırgan ve estetiklerdi.
Tüm Zamanlar GMT +3.5. Şu anda saat 17:10.
Sayfa 0.55866408 saniyede (100.00% PHP - 0% MySQL) 7 query kullanılarak yaratıldı.
