Geri   Modifiyem© > Club MdfyM > Otomobil Marka Takımları > Mitsubishi
Eski 22-11-2006, 00:17   #1
! TEAMRIDERS !
YzfR7 - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 12-05-2004
Mesaj: 2,168
Efsane... Mitsubishi Lancer EVO VI TM
Engine 4G63 Turbocharged Inline-4
position Front Transverse
aspiration TD05h Twin Scroll Turbocharger
valvetrain DOHC 4 Valves / Cyl
fuel feed ECI Electronic Multiport Injection
displacement 1997 cc / 121.9 cu in
bore 85.0 mm / 3.35 in
stroke 88.0 mm / 3.46 in
compression 8.8:1
power 208.8 kw / 280.0 bhp @ 6500 rpm
hp per litre 140.21 bhp per litre
bhp/weight 205.88 bhp per weight
torque 372.85 nm / 275 ft lbs
redline 7000
drive wheels Transverse Front Engine / 4WD
body / frame Unit Steel
front brakes Brembro Vented Discs w/4-Pot Calipers
f brake size 320 mm / 12.6 in
rear brakes Brembro Vented Discs w/2-Pot Calipers
r brake size 305 mm / 12.0 in
front wheels F 43.2 x 19.0 cm / 17.0 x 7.5 in
rear wheels R 43.2 x 19.0 cm / 17.0 x 7.5 in
front tire size 225/45ZR17
rear tire size 225/45ZR17
steering Rack & Pinion w/Power Assist
f suspension MacPherson Struts w/Col Springs, Lower Control Arms,
r suspension Multi-Link w/Coil Springs, Control Arms, Anti-Roll Bar
weight 1360 kg / 2998 lbs
wheelbase 2510 mm / 98.8 in
front track 1510 mm / 59.4 in
rear track 1505 mm / 59.3 in
length 4350 mm / 171.3 in
width 1770 mm / 69.7 in
height 1415 mm / 55.7 in
transmission 5-Speed Manual
gear ratios 2.785:1, 1.950:1, 1.407:1, 1.031:1, 0.761:1
final drive 4.529:1
top speed 240 kph / 149.1 mph
0 - 60 mph 5.7 seconds
YzfR7 Çevrimdışı   Alıntı Yaparak Cevapla
Eski 22-11-2006, 00:18   #2
! TEAMRIDERS !
Mesaj: 2,168
Re: Efsane... Mitsubishi Lancer EVO VI TM
Eski 22-11-2006, 00:20   #3
MdfyM Team
Kayıt Tarihi: 20-05-2004
Mesaj: 32,798
Hilal görmesin
Eski 22-11-2006, 00:21   #4
Gökhan
VeNoM_35 - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 30-04-2006
Şehir: KSK
Otomobil: Vectra GT
Mesaj: 5,840
Siyah süpermişşş, saol
LET's go !!!
VeNoM_35 Çevrimdışı   Alıntı Yaparak Cevapla
Eski 22-11-2006, 00:24   #5
! TEAMRIDERS !
Mesaj: 2,168
5. resim ayrı bir hava kattı konuya gerçekten
Eski 22-11-2006, 00:29   #6
TeaMitsubishi
FlaMe - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 30-03-2006
Otomobil: --
Mesaj: 7,417
Ercan eline koluna gözlerine sağlık çok teşşekkür ederim bir honda üyesinden bu tür bi hareket takdir edilecek bi davranış.
Ayrıca 5. resimde japon kardeşliğinide göstermen iyi oldu
FlaMe Çevrimdışı   Alıntı Yaparak Cevapla
Eski 22-11-2006, 00:30   #7
BNG & VTEC
KMR2-GT - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 17-08-2004
Şehir: ADANA
Otomobil: white civic VTİ
Mesaj: 7,506
vtec se koy sepete
KMR2-GT Çevrimdışı   Alıntı Yaparak Cevapla
Eski 22-11-2006, 00:47   #8
Kayıt Tarihi: 21-06-2004
Şehir: şehir
Otomobil: var
Mesaj: 10,530
Ercan siyah gerçekten güzelmiş... eline sağlık.. Kardeş takımımızı destkelemek lazım her fırsatta...
Evo mu alsam ne...
Darı unundan baklava,incir ağacından oklava olmaz.
Eski 22-11-2006, 00:55   #9
| That's All |
wroom - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 20-04-2006
Mesaj: 269
Bunlarda benden bir mitsu team üyesi olarak
wroom Çevrimdışı   Alıntı Yaparak Cevapla
Eski 22-11-2006, 00:56   #10
! TEAMRIDERS !
Mesaj: 2,168
yani Evo bambaşka bir olay abi.. Accord'un yerine olabilir
Tüm Zamanlar GMT +3.5. Şu anda saat 06:27.
Sayfa 0.27160001 saniyede (100.00% PHP - 0% MySQL) 7 query kullanılarak yaratıldı.
