| Eski Member |
SUBARU IMPREZA N11 TEKNİK ÖZELLİKLERİ ENGINE: Flat 4-cylinder boxer Capacity : 1994 cc Bore: 92.0mm Stroke : 75 mm Power: 270bhp @ 4500rpm Torque: 560Nm @ 3250rpm Turbo charger: IHI - Twin scroll roller bearing for improved response with regulation 32mm restrictor Spark plugs: NGK ECU: Engine: Prodrive - Pectel programmable individually mapped for various fuels Centre diff: Prodrive - Pectel programmable EXHAUST: Hi-flow motorsport catalyst + 98dB silencer (options available) SUSPENSION : Front: Prodrive-Ohlins Macpherson strut, 3 way adjustable with hydraulic bump stops Rear: Prodrive-Ohlins Macpherson strut, 3 way adjustable with hydraulic bump stops - longitudinal and transverse link FUEL SYSTEM: FIA approved FT3-99 80 litre safety tank centrally mounted under the flor TRANSMISSION : Gear box: Prodrive 5-speed manual dog engagement Front diff: Plated limited slip Centre diff: Electro mechanical, locking differential Rear diff: Plated limited slip CLUTCH: Alcon, 240mm 6 paddle competition, single plate ROLLCAGE: FIA approved and homologated. Conforms to latest regulations with improved torsional stiffness SUSPENSİON: Front: 54mm Prodrive-Ohlins Macpherson strut, 3-way adjustable with hydraulic bump stops Rear: 50mm Prodrive-Ohlins Macpherson strut, 3-way adjustable with hydraulic bump stops - longitudinal and transverse link For gravel and tarmac - rough or smooth BRAKES: Tarmac: Brembo calipers Front: Four piston | Rear:Two piston Discs Front: 326mm | Rear: 316mm Gravel: Subaru calipers Front: Four piston | Rear: Two piston Discs Front: 294mm | Rear: 290mm STEERING: Power assisted quickrack (13:1) for left and right hand drive WHEELS: Tarmac: 8" x 17" | Gravel: 7" x 15" | Snow: 5.5" x 16" MINIMUM CAR WEIGHT: 1271 kgs CAR DIMENSIONS: Front track: 1510 mm Rear track: 1515 mm Length: 4415 mm Wheelbase: 2540 mm UBARU IMPREZA N12 TEKNİK ÖZELLİKLERİ ENGINE: Flat 4-cylinder boxer Capacity : 1994 cc Bore: 92.0 mm Stroke : 75.0 mm Power: 270bhp @ 4500rpm Torque: 560Nm @ 3250rpm Turbo charger: IHI – twin scroll roller bearing for improved response with regulation 32 mm restrictor Spark plugs: NGK ECU: Engine: Prodrive – Pectel programmable individually mapped for various fuels Centre diff: Prodrive – Pectel programmable EXHAUST: Hi-flow motorsport catalyst + 98 dB silencer (options available) SUSPENSION : Front: 54 mm Prodrive – Ohlins Macpherson strut,three-way adjustable with hydraulic bump stops Rear: 50 mm Prodrive – Ohlins Macpherson strut, three-way adjustable with hydraulic bump stops – longitudinal and transverse link FUEL SYSTEM: FIA approved FT3 – 99 80 litre safety tank centrally mounted under the flor TRANSMISSION : Gear box: Prodrive five speed manual dog engagement Front diff: Plated limited slip Centre diff: Electro mechanical, locking Rear diff: Plated limited slip CLUTCH: Alcon, 240 mm six paddle competition, single plate homologated STI cover ROLLCAGE: FIA approved and homologated. Conforms to latest regulation with improved torsional stiffness BRAKES: Tarmac: Calipers Front: Four piston | Rear: Four piston Discs Front: 355 mm | Rear: 285 mm Gravel: Calipers Front: Four piston | Rear: Four piston Discs Front: 295mm | Rear: 285mm STEERING: Power assisted quickrack (13:1) for left and right hand drive WHEELS: Tarmac: 8" x 17" | Gravel: 7" x 15" | Snow: 5.5" x 16" MINIMUM CAR WEIGHT:1345 kg CAR DIMENSIONS: Front track: 1510 mm Rear track: 1515 mm Length: 4415 mm Wheelbase: 2540 mm UBARU S11 WRC TEKNİK ÖZELLİKLERİ Capacity : 1994 cc Bore: 92.0mm Stroke : 75.0mm Power: 325bhp @ 5000rpm Torque: 555Nm @ 3250rpm Turbo charger: IHI with WRC regulation 34mm restrictor and latest anti-lag system. Data system: TAG electronics. Integrated engine & transmission control with data logging. 256 Mbyte logging memory, card reader type. Display screens for driver and co- driver. TRANSMISSION :Prodrive 6 speed semi-auto. Three fully active differentials. Xtrac epicyclic rear differential. CLUTCH : Alcon, carbon twin plate. SUSPENSION: Sachs 4 way adjustable Macpherson strut. STEERING: Power assisted rack and pinion, sealed system. 1770mm 2525mm BRAKES Tarmac Front Rear Prodrive Alcon 6 piston 4 piston Discs 366mm 304mm Gravel Prodrive Alcon 6 piston 4 piston Discs 304mm 304mm LAUNCH CONTROL Turbo and clutch management. Auto 1st to 2nd gear change. Anti-stall function. FUEL SYSTEM 90 litre FIA approved safety tank
