Geri   Modifiyem© > Club MdfyM > Otomobil Marka Takımları > Ford
Eski 28-10-2007, 19:29   #1
Rs
Kayıt Tarihi: 29-09-2005
Otomobil: Sierra 2lt modified
Mesaj: 6,018
Arrow Sierra Saphire Cosworth 2wd 800+hp 200mph + top speed
Engine Specification
2150 c.c. DOHC 4 cylinder 16 V : Custom linered block : 7.2:1 pistons : custom con-rods : custom crank : Group'A' Big-end bolts : Double length head studs High pressure oil pump : Baffled sump : Gas flowed & ported head : Uprated valve springs : Bronze valve guides : WRC Head gasket
M.A Development profile cams : 4 x 1200cc injectors : Autronics SM4 ECU/CDI : 4 coil ignition : Swirl Pot : Automotive fuel pump : RS500-Throttle body
GT40/88 Turbo-charger : External wastegate : SPEC-R Turbo Pre-Radiator : Autronic Closed-loop boost control : SPEC-R Group ‘ A’ Dump valve Induction kit : RS500 Intercooler : Large Capacity Radiator : SPEC-R High Pressure Header Tank : Samco Hoses : M.A Development Breather System
Tubular exhaust manifold : 3.5" Stainless Steel Exhaust : Mapped Water Injection : Oil-Cooler : 15v accuvolt system
Nitrous
Highpower 200bhp Direct-port system : 1500psi Nitrogen 'push' system : Powermax Progressive controller : Purge valve
Transmission
Tremec TKO ( 9310 Road/Race gears ):PRO 5.0 Quick Shift : Hydraulic triple plate clutch
Differential
Jaguar 10.5": 3.54 CWP :
Brakes
330mm discs/6pot calipers - Front : 300mm disc /4x4 calipers - Rear : Up-rated Pads :
Suspension
Leda height/rate adjustable coilovers - Front/Rear : Zoo Motorsport rear beam kit
Mesajı son düzenleyen sierra_rs : 28-10-2007 - 19:41
Eski 28-10-2007, 19:30   #2
Rs
Mesaj: 6,018
Re: Sierra Saphire Cosworth 2wd 800+hp 200mph + top speed
Eski 28-10-2007, 19:32   #3
Boss
Mustafa Salih Küçükdoğan - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 26-03-2005
Otomobil: CC5
Mesaj: 6,923
cenk senın arac daha kral duruo bosver bunu
Ötv'ye hayır değil bu ulkeye ötv'yi getiren cıkarcı adi zihniyete hayr
Mustafa Salih Küçükdoğan Çevrimdışı   Alıntı Yaparak Cevapla
Eski 28-10-2007, 19:33   #4
Rs
Mesaj: 6,018
Harbimi kanka Eyvallah ama bir turbo olsa fena olmaz
Eski 28-10-2007, 19:36   #5
Boss
Otomobil: CC5
Mesaj: 6,923
kanka oda olur ama bu kdar buuyugune gerek yokk olum senın aracın resımlerı nerde yenı motor fılan vıdeo da yok nıe koymuon lann ayar etme lannnn benı koysana resımlerını
Eski 28-10-2007, 19:38   #6
Fast1ng - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 20-01-2007
Mesaj: 156
Ahhhh bunu siyaha çevirip bana verecekler varya
Dağlar kurdun, yollar Ford'un..!
modifiyem'in en güçlü Sierrası
Fast1ng Çevrimdışı   Alıntı Yaparak Cevapla
Eski 28-10-2007, 19:39   #7
Rs
Mesaj: 6,018
Orjinal Mesaj Sahibi Mustafa Salih Küçükdoğan Mesajı Göster
Kanka benim konuda var resimler Yollarım linkini
2 sene sonra throttle body yapıcam kısmetse kanka
Eski 28-10-2007, 19:39   #8
Rs
Mesaj: 6,018
Orjinal Mesaj Sahibi Fast1ng Mesajı Göster
Bu haldede binilir kanka süper duruyor ya
Eski 28-10-2007, 19:50   #9
TeamRS
Mesaj: 10,303
Çok güzel hazırlanmış. sağol cenk.
Eski 28-10-2007, 19:53   #10
Boss
Otomobil: CC5
Mesaj: 6,923
kanka resımlerı gordum masallah 10 numara duruo valla kazasız belasız
Tüm Zamanlar GMT +3.5. Şu anda saat 05:18.
Sayfa 0.27095699 saniyede (100.00% PHP - 0% MySQL) 7 query kullanılarak yaratıldı.
