Geri   Modifiyem© > Club MdfyM > Otomobil Marka Takımları > Ford
Eski 26-09-2007, 03:20   #1
TeamRS
Mesaj: 10,303
Sierra RS Cosworth 405hp Rebuild
Eski 26-09-2007, 03:21   #2
TeamRS
Mesaj: 10,303
Re: Sierra RS Cosworth 405hp Rebuild
Eski 26-09-2007, 03:21   #3
TeamRS
Mesaj: 10,303
ENGINE
200 COSWORTH BLOCK
STANDARD STEEL CRANK, STANDARD STEEL CON RODS
GENUINE COSWORTH PISTONS
LOW COMPRESSION (7.6:1)
HIGH PRESSURE OIL PUMP
BIG WINGED SUMP (1 litre extra)
WRC METAL 4 LAYER HEAD GASKET
LONG STUDDED
4X4 POLISHED & PORTED HEAD
HARVEY GIBBS CAMS
KENT ADJUSTABLE VERNIERS
PORTED INLET MANIFOLD AND PLENUM
INLET MANIFOLD ‘O’ RINGED
4X4 EXHAUST MANIFOLD
GT28 ROLLER BEARING TURBO WITH MODIFIED T34 FRONT HOUSING
GARRETT –31 ACTUATOR
GROUP A CAM BELT
GROUP A COIL
GENUINE RS500 INTERCOOLER WITH MODIFIED T34 FITTINGS
PACE RS500 FAST ROAD RADIATOR (50mm core)
PRO-ALLOY SLIMLINE UPRATED COOLING FANS
PACE TURBO COOLER
BAILEY MOTORSPORT TURBO OIL FEED & PRE FILTER
SPEC-R GROUP A BREATHER/SEPARATOR SYSTEM
SPEC-R CAMBELT COVER
SPEC-R SWIRL POT
SPEC-R WATER COOLED POWER STEERING TANK
SPEC-R HEADER TANK (with sight glass)
SPEC-R WASHER BOTTLE
STANT 21-25psi RADIATOR CAP WITH LEVER RELEASE
SAMCO BOOST & WATER HOSES
BRAIDED FUEL HOSE -6 WITH EARLS FITTINGS AND CLAMPS
(from filter to fuel rail, and regultor to tank)
MIKALOR STAINLESS STEEL HOSE CLAMPS THROUGHOUT
2 AIR SCOOPES ABOVE INTERCOOLER WITH DUCTING TO AIR FILTER
MONGOOSE 3in STAINLESS STEEL EXHAUST (with Powerflex hangers)
K&N GROUP A CONE FILTER
WEBBER MARELLI LEVEL 8 ECU WITH PECTEL BABY BOARD
PECTEL 12 POSITION BOOST CONTROL (in car)
4 X 403 GREY INJECTORS (503cc)
WRC AIR INJECTORS WITH –4 BRAIDED HOSE AND EARLS FITTINGS
WATER INJECTION
044 FUEL PUMP
3 BAR MAP SENSOR
MOTORCRAFT AGP 701 SPARK PLUGS
FORD MOTORSPORT IGNITION LEADS
MILLERS 10w60 FULLY SYNTHETIC OIL
9 OIL COOLER FOR POWER STEERING
TRANSMISSION
STANDARD BORG WARNER T5 WITH QUICKSHIFT
CASTROL AUTOMATIC TRANSMISSION FLUID (as standard)
LIGHTENED & BALANCED FLY WHEEL
ALCON 6 PADDLE, STANDARD FORD COVER
RECONDITIONED PROPSHAFT WITH UPRATED UJ’S
QUAIFE ATB 7 ½ INCH DIFF, 3.64:1 FINAL DRIVE (standard)
CASTROL EP80W-90 OIL
POWER
405 bhp @ 6030 rpm
397 lbft TORQUE @ 4020 rpm
REV LIMITER : 7100 rpm
PEAKS @ 32 psi, HOLDS 28psi
BUILT & TUNED BY HARVEY GIBBS
SCS, PETERBOROUGH. 01733 576614
MAPPED BY AHMED BAYJOO ON DYNO & IN CAR
BRAKES
FRONT: AP RACING CP5555 6 POT CALIPERS
330mm x 28mm DISCS & BELLS
FERRADO DS2500 PADS
REAR: 4x4 CALIPERS
300mm x 22mm DISCS & BELLS
FERRADO PADS
GOODRIDGE BRAIDED HOSES ALL ROUND
CASTROL SRF DOT 4 BRAKE FLUID
SUSPENSION
FRONT: GAZ COILOVERS
10 INCH SPRINGS, 325 LB
POLY BUSHED ANTI ROLL BAR AND TRACK CONTROL ARMS (inner
& outer)
SPEC-R TWIN BAR STRUT BRACE (chromed)
REAR: GAZ COILOVERS
12 INCH SPRINGS, 225LB
GROUP N REAR BEAM BUSHES (donuts)
STANDARD FORD TRAILING ARM BUSHES
POLY BUSHED REAR ANTI ROLL BAR
REAR SHIM KIT
SPEC-R REAR STRUT BRACE
INTERIOR
STANDARD RECARO INTERIOR
RS MOTORSPORT 3 SPOKE STEERING WHEEL
WILLINS 4 POINT HARNESSES
ELLIOT 8000 RPM REV COUNTER
DEFI OIL PRESSURE & TEMPERATURE AND EXHAUST GAS TEMPERATURE
DEFI CONTROLLER (with record and playback)
APEXI 2.5 BAR BOOST GUAGE (with record and playback)
S.E.C.S MONITER
PECTAL 12 POSITION BOOST CONTROL
SPEC-R WATER INJECTION TANK IN BOOT
FIRE EXTINGUISHER
EXTERIOR
FRONT WHEELS : COMPOMOTIVE MO, 7 I/2in x 17in ET 37
GOODYEAR EAGLE F1’s 215/40
REAR WHEELS : COMPOMOTIVE MO, 8in x 17in ET 35
ALL PAINTED IN ANTHRACITE WITH DIAMOND CUT & POLISHED RIM
GENUINE RS500 FRONT SPLITTER
GENUINE RS500 FOGLIGHT GRILLES, WITH AIR DUCTING TO AIR FILTER
SPEC-R REAR BUMPER/EXHAUST HEAT SHIELD
Mesajı son düzenleyen OmerRS : 26-09-2007 - 03:27
Eski 26-09-2007, 03:23   #4
...TeaM RiderS...
cHeeRs - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 07-04-2005
Mesaj: 6,526
gör cenk gör
ne cevherler var
cHeeRs Çevrimdışı   Alıntı Yaparak Cevapla
Eski 26-09-2007, 03:24   #5
Tamed Racing Driver
Kayıt Tarihi: 17-09-2006
Mesaj: 1,025
allah sahibine bağışlasın
TheStig Çevrimdışı   Alıntı Yaparak Cevapla
Eski 26-09-2007, 03:25   #6
Gti
yaya forever
Gti - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 27-04-2004
Mesaj: 9,720
eksılınt :!
harika yaw , ömer sağolasın
Çıldırın!
Gti Çevrimdışı   Alıntı Yaparak Cevapla
Eski 26-09-2007, 03:25   #7
***2.ÇARKÇI***
wolrath - İsimli Kullanıcıya Ait Avatar
Kayıt Tarihi: 13-07-2005
Mesaj: 9,970
ohannes..super ya..
escort yapsınlar ama
wolrath Çevrimdışı   Alıntı Yaparak Cevapla
Eski 26-09-2007, 03:28   #8
Freddy Kruegger
Kayıt Tarihi: 19-06-2005
Otomobil: BMW 3 18i e46
Mesaj: 6,911
bunun baslangıcı da var dıye bılıyorum tamamen paslı falan olması lazım en basta arac sagol Omer
leventse Çevrimdışı   Alıntı Yaparak Cevapla
Eski 26-09-2007, 04:00   #9
TeamRS
Mesaj: 10,303
Beğendiğinize sevindim harika olmuş cidden.
Eski 26-09-2007, 04:05   #10
***2.ÇARKÇI***
Mesaj: 9,970
Orjinal Mesaj Sahibi OmerRS Mesajı Göster
begnemmek elde mi omer.? emege baksana.. ıcım gıdıyor bu sekılde temız ıslere.bızım ıcın ımkansız.cok para lazım hele trde..öff...
Tüm Zamanlar GMT +3.5. Şu anda saat 07:56.
Sayfa 0.31655097 saniyede (100.00% PHP - 0% MySQL) 7 query kullanılarak yaratıldı.
