| GERMANIAC ÜYE Kayıt Tarihi: 01-10-2007
Mesaj: 821
| BMW 335i severler ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Introducing the latest expression of individual style - the all-new BMW 3 Series Coupe. With totally new looks, the newest BMW Coupe once again sets the benchmark for elegant design, luxury and value. In true BMW tradition, it also establishes a new standard of performance and driving dynamics with the introduction of an exceptional engine: the first inline six-cylinder with twin-turbochargers, high-precision fuel injection, and an all-aluminum crankcase. The performance potential of this new 300 horsepower engine ensures that the 335i Coupe offers a significant improvement in performance while maintaining a level of efficiency for which the BMW 3 Series is renowned. The 335i Coupe will be joined in the U.S. by the 230 horsepower 328i Coupe. In addition to the standard six-speed manual, both models will be offered with an available six-speed STEPTRONIC automatic transmission. Designed for responsiveness, the new automatic enhances driving dynamics without sacrificing fuel efficiency. An additional dimension of driving dynamics, with the benefit of outstanding traction, will be offered with the introduction of BMW's xDrive all-wheel drive. BMW xDrive has proven its merits, in terms of agility and safety, in the ten models currently offered with xDrive in the U.S. Beginning this fall these merits will become available to Coupe drivers for the first time. Unique in Its Design Details The character of any coupe is reflected in its profile. On the new BMW 3 Series Coupe the profile is unmistakably BMW. The long hood reflects BMW's adherence to its tradition of inline six-cylinder engines. The long wheelbase, the passenger compartment set back as well as the low, sleek roofline which slopes gently into the trunk, are all characteristic of BMW Coupes. In addition to the classic proportions, the shoulder, character and sill lines serve to enhance the sleek appearance. Both the shoulder line and character line stretch uninterrupted to the back of the car, allowing one's eye to move quickly and smoothly from front to rear along the entire length of the car. The sill line on the lower edge of the door also flows into the front and rear air dams, reinforcing the dynamic nature of BMW's newest Coupe. Twin-Turbo Inline Six-Cylinder Engine The most powerful engine within BMW's wide range of inline six driving machines that does not wear an "M" badge is the new BMW 335i Coupe. This brand-new version develops maximum output of 300 bhp in US-spec from 3.0 liters and generates peak torque of 300 lb-ft for powerful acceleration in any situation. The combination of turbocharging and direct gasoline fuel injection offers a new dimension to efficient dynamics. Featuring high-precision fuel injection, the engine boasts a highly sophisticated and advanced direct fuel injection system. This new high-performance engine gives the light, aerodynamically sculpted Coupe truly outstanding acceleration and flexibility on the road. The twin turbo powerplant in the BMW 335i Coupe develops its power and performance much more spontaneously than a turbocharged engine of conventional design. Thanks to their lower inertia, the two small turbochargers build up pressure much faster than a single, large turbocharger, thus eliminating even the slightest turbo "lag". To enhance the engine efficiency to an even higher level, the turbochargers are made of a particularly heat-resistant material which makes them immune to high exhaust gas temperatures in the interest of a fuel-efficient combustion process particularly under full load. As a result, the twin turbo technology in the BMW 335i Coupe represents a significant achievement in terms of both performance and fuel economy. The advantages over a conventional turbocharged engine are not only clearly measurable, but also easy to feel on the road. Chassis and Suspension Traditional rear-wheel drive and a near 50:50 front-to-rear weight distribution give the new BMW 3 Series Coupe ideal qualities for optimum driving dynamics. This, in combination with the high-tech suspension, enables the driver to convert the power and performance of the engine into an exhilarating driving experience. Boasting a double-pivot front suspension with spring struts made almost entirely of aluminum in combination with a five-link suspension at the rear, the new BMW 3 Series Coupe has the most advanced and sophisticated suspension in its class. The high-performance brake system requires 17-inch wheels to match the larger diameter of the brake discs which ensure outstanding stopping power and deceleration. Brake performance is further enhanced by BMW's latest Dynamic Stability Control. Introduced on the 3 Series Sedan, BMW's latest DSC incorporates several new functions. For example, DSC works to counteract the slightest brake fading effect even at extremely high brake temperatures by increasing brake pressure accordingly. This ensures maximum brake power even under the toughest conditions, without requiring the driver to exert any higher pressure. The Interior: Impressive Standard and Optional Equipment Through its design and configuration, the cockpit emphasizes the sporting and driver-oriented character of BMW's new Coupe. Taking a seat behind the wheel, the driver will immediately focus on a newly designed instrument cluster which includes an oil temperature gauge positioned below the tachometer. Buckling up in the new BMW 3 Series Coupe, both the driver and front passenger benefit from the newly developed belt feeder arm: The seat belt integrated in the B-pillar, moved back in typical coupe fashion, is automatically "delivered" to the driver and front passenger once they close the door and once the key has been inserted into the ignition slot. Connected to the seat occupancy detector, the passenger-side belt feeder arm is only activated when the front passenger has actually taken a seat. With the belt delivery unit housed conveniently within the side panels, this new system does not impair the elegant look of the interior. Specifications Engine Type: Twin-Turbo Inline-6 Displacement cu in (cc): 182 (2979) Power bhp (kW) at RPM: 300(224) / 5800 Torque lb-ft (Nm) at RPM: 300(407) / 1400-5000 Redline at RPM: 7000 Brakes & Tires Brakes F/R: ABS, vented disc/disc Tires F-R: 225/45 R17 Driveline: Rear Wheel Drive Exterior Dimensions & Weight Length × Width × Height in: 180.6 × 70.2 × 54.1 Weight lb (kg): 3571 (1621) Performance Acceleration 0-60 mph s: 5.3 Top Speed mph (km/h): 150 (241) - electronically limited Fuel Economy EPA city/highway mpg (l/100 km): 19/29 (n.a.)
| Türkiye Türklerindir!!!! | Re: BMW 335i severler
Diyecek pek fazla şey yok.. Harika...
| Aktif Üye Kayıt Tarihi: 29-07-2007 Yaş: 39
Mesaj: 169
Nefret, iğrenççç... Bu kasada 335d turbodizel motor olmalıydı. Olmamış, becerememişler. Zararın neresinden dönülse kardır, tekrar denesinler... ![]() Not: Bu kasada kırmızı renk daha iyi oluyor sanki... Mesajı son düzenleyen Chetuo : 10-10-2007 - 03:00 |
| Gökhan Kayıt Tarihi: 30-04-2006 Şehir: KSK Otomobil: Vectra GT
Mesaj: 5,842
Gri olan çok güzel bence..
| © Kayıt Tarihi: 02-07-2005 Şehir: ankara Otomobil: 9n
Mesaj: 9,059
üzücü bir biçimde std E92'nin M3den daha hoş göründüğünü düşünmekteyim.
__________________ www.travian.com.tr |
Mesaj: 5,842
Açıkcası biraz katılıyorum, pek girintili çıkıntılı olmuş M3..
| İRMSCHER VECTRA & (BMW) Kayıt Tarihi: 08-01-2005 Yaş: 24
Mesaj: 225
mükemmel bir arac.. sesini duyduğumda tüylerim diken diken olmuştu..
| Fire Fighter Kayıt Tarihi: 08-02-2007 Şehir: İstanbul-Bakırköy Yaş: 29 Otomobil: Jeep Grand Cherokee 5.2 V8
Mesaj: 6,949
guzel arac..
| | #9 | |
hahahahaa mükemmel | |
