| --- Kayıt Tarihi: 14-05-2006 Şehir: . Otomobil: .
Mesaj: 5,134
| Opel motor kodları
All engines manufactured by Vauxhall/Opel - as with those of all vehicle manufacturers - have identification codes, which reveal information about a particular engine. For clarity, an example of a Vauxhall/Opel engine identification code is 'C20LET'. See that engine's node for explanation of the engine and how the designation relates to its specification. The standard form of such an identification number (for petrol engines, as opposed to diesel engines) is as follows: ABBCCDE Where: A = Exhaust emission standard ahered to by the engine in question (in this case, they are European Community directives pertaining to emission limits). One of the following: 'C' = EC 91/441/EEC 'X' = EC 91/441/EEC (stage 2) Where there is no letter, the engine adheres to EC directive ECE R 83 A. B = Engine capacity in cubic centimetres (cc). This is a two digit number - e.g. '20' means 2.0 litres, '35' means 3.5 litres. C = Compression Ratio. One of the following: 'G' = less than or equal to 8.5:1 'L' = 8.5:1 to 9.0:1 'N' = 9.0:1 to 9.5:1 'S' = 9.5:1 to 10.0:1 'X' = 10.0:1 to 11.5:1 'Y' = more than or equal to 11.5:1 D = Mixture system. One of the following: 'E' = Multi-point fuel injection 'Z' = Central injection 'V' = Carburettor E = Specific vehicle version. This is often not used, and little information exists on the meaning of all the variants of this segment of the code. Some of them are: 'H' = High output/supercharging 'V' = Volume model 'R' = Increased output 'T' = Turbo As an example, one of Vauxhall/Opel's recent engines, the X25XE (going through the identification in part order): X - adheres to EC emission directive EC 91/441/EEC (stage 2) 25 - has a 2.5 litre capacity X - has a compression ratio of 10.0:1 to 11.5:1 E - has multi-point fuel injection. In addition to this, if one were to search out the engine number of the particular engine (as found stamped on the engine block, usually in front of the clutch housing), one would likely find an extended version of the code as described above, with further details in the form: ABBCCDEFFGGGGG ABBCCDE are as described above. FF = Country of manufacture. One of the following: '01' = Rüesselsheim '02' = Bochum '08' = Ellesmere Port '14' = Kaiserslautern '19' = Aspern '20' = Hungary '25' = Holden '31' = Brazil '0S' = Szentgotthard GGGGG is the engine serial number. Agila Z10XE 3 973 43/58 Benziner 1.4 - 2.2 Ecotec Z12XE 4 1199 55/75 Benziner 1.4 - 2.2 Ecotec Ascona A / Manta A (Bj. 1970-1975) 12S 4 1187 44/60 Benziner OHV 16N 4 1566 44/60 Benziner CIH 16S 4 1566 55/75 Benziner CIH 19S 4 1875 65/90 Benziner CIH 19E 4 1875 77/105 Benziner CIH Ascona B / Manta B (Bj. 1976-1981) 12N 4 1187 40/55 Benziner OHV 12S 4 1187 44/60 Benziner OHV 13N 4 1281 44/60 Benziner OHC 13S 4 1281 55/75 Benziner OHC 16N 4 1566 44/60 Benziner CIH 16S 4 1566 55/75 Benziner CIH 18S 4 1771 66/90 Benziner OHC 19N 4 1875 55/75 Benziner CIH 19S 4 1875 66/90 Benziner CIH 19E 4 1875 77/105 Benziner CIH 20N 4 1956 66/90 Benziner CIH 20S 4 1956 74/100 Benziner CIH 20E 4 1956 81/110 Benziner CIH I20E 4 1956 92/125 Benziner CIH 24E 4 2390 106/144 Benziner A400 Ascona C (Bj. 1982-1988) 13N 4 1281 44/60 Benziner OHC 13S 4 1281 55/75 Benziner OHC 16N 4 1587 55/75 Benziner OHC 16S 4 1587 Benziner OHC 16SH 4 1587 66/90 Benziner OHC 16SV 4 1587 60/82 Benziner OHC E16NZ 4 1587 55/75 Benziner OHC C16LZ 4 1587 55/75 Benziner OHC C16NZ 4 1587 55/75 Benziner OHC 18E 4 1771 85/115 Benziner OHC 18SE 4 1771 82/112 Benziner OHC C18NE 4 1771 74/100 Benziner OHC E18NV 4 1771 62/84 Benziner OHC S18NV 4 1771 Benziner OHC 20NE 4 1984 85/115 Benziner OHC C20NE 4 1984 85/115 Benziner OHC C20NEF 4 1984 74/100 Benziner OHC 20SEH 4 1984 95/130 Benziner OHC Astra Classic (Bj. 1999- ) X14NZ 4 1389 Benziner OHC X16SZR 4 1598 55/75 Benziner OHC X16XEL 4 1598 74/100 Benziner 1.4 - 2.2 Ecotec Astra F (Bj. 1992-1998) 14NV 4 1389 55/75 Benziner OHC C14NZ 4 1389 44/60 Benziner OHC X14NZ 4 1389 Benziner OHC 14SE 4 1389 60/82 Benziner OHC C14SE 4 1389 60/82 Benziner OHC X14XE 4 1389 66/90 Benziner 1.4 - 2.2 Ecotec 16LZ2 4 1598 55/75 Benziner OHC 16NZ2 4 1598 Benziner OHC 16NZR 4 1598 Benziner OHC C16NZ 4 1598 55/75 Benziner OHC X16SZ 4 1598 52/71 Benziner OHC X16SZR 4 1598 55/75 Benziner OHC C16SE 4 1598 74/100 Benziner OHC X16NE 4 1598 Benziner OHC X16XEL 4 1598 74/100 Benziner 1.4 - 2.2 Ecotec 18SE 4 1796 Benziner OHC C18NZ 4 1796 66/90 Benziner OHC C18SEL 4 1796 Benziner OHC C18XE 4 1796 92/125 Benziner 1.4 - 2.2 Ecotec X18XE 4 1796 85/115 Benziner 1.4 - 2.2 Ecotec C18XEL 4 1796 85/115 Benziner 1.4 - 2.2 Ecotec C20NE 4 1998 85/115 Benziner OHC X20XEV 4 1998 100/136 Benziner 1.4 - 2.2 Ecotec C20XE 4 1998 110/150 Benziner DOHC Astra G (Bj. 1998- ) X12XE 4 1199 Benziner 1.4 - 2.2 Ecotec Z12XE 4 1199 55/75 Benziner 1.4 - 2.2 Ecotec X14XE 4 1389 Benziner 1.4 - 2.2 Ecotec Z14XE 4 1389 Benziner 1.4 - 2.2 Ecotec X16SZR 4 1598 55/75 Benziner OHC Z16SE 4 1598 62/85 Benziner OHC C16SEL 4 1598 Benziner 1.4 - 2.2 Ecotec X16XEL 4 1598 74/100 Benziner 1.4 - 2.2 Ecotec Z16XE 4 1598 74/100 Benziner 1.4 - 2.2 Ecotec X18XE1 4 1796 85/115 Benziner 1.4 - 2.2 Ecotec Z18XE 4 1796 92/125 Benziner 1.4 - 2.2 Ecotec Z18XEL 4 1796 Benziner 1.4 - 2.2 Ecotec X20XER 4 1998 Benziner 1.4 - 2.2 Ecotec X20XEV 4 1998 100/136 Benziner 1.4 - 2.2 Ecotec Z20LET 4 1998 141/192 Benziner Turbo 1.4 - 2.2 Ecotec Z22SE 4 2198 108/147 Benziner 1.4 - 2.2 Ecotec Calibra (Bj. 1989-1997) C20NE 4 1984 85/115 Benziner OHC C20XE 4 1984 110/150 Benziner DOHC X20XEV 4 1984 100/136 Benziner 1.4 - 2.2 Ecotec C20LET 4 1984 150/204 Benziner Turbo DOHC C25XE 6 2498 125/170 Benziner V6 X25XE 6 2498 Benziner V6 Commodore C (Bj. 1978-1986) 25S 6 2461 85/115 Benziner CIH 25E 6 2461 96/130 Benziner CIH Corsa A (Bj. 1983-1992) 10S 4 986 33/45 Benziner OHV 12N 4 1187 33/45 Benziner OHV 12NC 4 1187 33/45 Benziner OHV E12GV 4 1187 33/45 Benziner OHV 12S 4 1171 40/55 Benziner OHC 12ST 4 1196 40/55 Benziner OHC 12NV 4 1196 38/52 Benziner OHC C12NZ 4 1196 33/45 Benziner OHC 13S 4 1281 51/70 Benziner OHC 13SB 4 1281 51/70 Benziner OHC 13NB 4 1281 44/60 Benziner OHC C13N 4 1281 44/60 Benziner OHC 14NV 4 1389 44/60 Benziner OHC C14SE 4 1389 60/82 Benziner OHC C14NZ 4 1389 44/60 Benziner OHC E16SE 4 1587 74/100 Benziner OHC C16SE 4 1587 72/98 Benziner OHC C16NZ 4 1587 55/75 Benziner OHC Corsa B (Bj. 1993-2001) X10XE 3 973 40/54 Benziner 1.4 - 2.2 Ecotec 12NZ 4 1195 33/45 Benziner OHC C12NZ 4 1195 33/45 Benziner OHC X12SZ 4 1195 33/45 Benziner OHC X12XE 4 1199 48/65 Benziner 1.4 - 2.2 Ecotec 13NE 4 1281 Benziner OHC C14NZ 4 1389 44/60 Benziner OHC X14SZ 4 1389 44/60 Benziner OHC C14SE 4 1389 60/82 Benziner OHC C14SEL 4 1389 Benziner 1.4 - 2.2 Ecotec X14XE 4 1389 66/90 Benziner 1.4 - 2.2 Ecotec C16SEL 4 1598 Benziner 1.4 - 2.2 Ecotec C16XE 4 1598 80/109 Benziner 1.4 - 2.2 Ecotec X16XE 4 1598 78/106 Benziner 1.4 - 2.2 Ecotec Corsa C (Bj. 2001- ) Z10XE 3 973 43/58 Benziner 1.4 - 2.2 Ecotec Z12XE 4 1199 55/75 Benziner 1.4 - 2.2 Ecotec Z14XE 4 1389 66/90 Benziner 1.4 - 2.2 Ecotec Z16SE 4 1598 Benziner OHC Z18XE 4 1796 92/125 Benziner 1.4 - 2.2 Ecotec Frontera A (Bj. 1992-1998) C20NE 4 1998 85/115 Benziner OHC X20SE 4 1998 85/115 Benziner OHC X22XE 4 2198 100/136 Benziner 1.4 - 2.2 Ecotec C24NE 4 2410 92/125 Benziner CIH Frontera B (Bj. 1999- ) X22SE 4 2198 Benziner 1.4 - 2.2 Ecotec Y22SE 4 2198 100/136 Benziner 1.4 - 2.2 Ecotec GT (Bj. 1968-1973) 11S 4 1078 44/60 Benziner OHV 19S 4 1875 66/90 Benziner CIH Kadett B/C (Bj. 1965-1979) 10N 4 986 29/40 Benziner OHV 10S 4 986 35/48 Benziner OHV 11N/L/SR 4 1078 33/45 Benziner OHV 11S 4 1078 41/55 Benziner OHV 12N 4 1187 38/52 Benziner OHV 12S 4 1187 44/60 Benziner OHV 16S 4 1566 55/75 Benziner CIH 19E 4 1875 77/105 Benziner CIH 20E 4 1956 81/110 Benziner CIH 20EH 4 1956 85/115 Benziner CIH Kadett D (Bj. 1980-1984) 10S 4 986 Benziner OHV 12N 4 1187 39/53 Benziner OHV 12S 4 1187 44/60 Benziner OHV 12ST 4 1171 40/55 Benziner OHC 13N 4 1281 44/60 Benziner OHC 13S 4 1281 55/75 Benziner OHC 16S 4 1566 Benziner OHC 16SH 4 1587 66/90 Benziner OHC 18E 4 1771 85/115 Benziner OHC Kadett E (Bj. 1985-1993) 12SOHV 4 1187 44/60 Benziner OHV 12SCOHV 4 1187 40/55 Benziner OHV 12SOHC 4 1171 40/55 Benziner OHC 12STOHC 4 1171 40/55 Benziner OHC 13N 4 1281 44/60 Benziner OHC 13NB 4 1281 44/60 Benziner OHC 13S 4 1281 55/75 Benziner OHC C13N 4 1281 44/60 Benziner OHC 14NV 4 1389 55/75 Benziner OHC C14NZ 4 1389 44/60 Benziner OHC 16SH 4 1587 66/90 Benziner OHC 16SV 4 1587 60/82 Benziner OHC E16NZ 4 1587 55/75 Benziner OHC C16LZ 4 1587 55/75 Benziner OHC C16NZ 4 1587 55/75 Benziner OHC 18E 4 1771 85/115 Benziner OHC 18SE 4 1771 82/112 Benziner OHC E18NV 4 1771 62/84 Benziner OHC S18NV 4 1771 Benziner OHC C18NE 4 1771 74/100 Benziner OHC C18NT 4 1771 66/90 Benziner OHC C18NZ 4 1771 66/90 Benziner OHC 20NE 4 1984 85/115 Benziner OHC C20NE 4 1984 85/115 Benziner OHC 20SEH 4 1984 95/130 Benziner OHC 20SER 4 1984 91/124 Benziner OHC 20XE 4 1984 110/150 Benziner DOHC 20XEJ 4 1984 110/150 Benziner DOHC C20XE 4 1984 110/150 Benziner DOHC Monza / Senator A (Bj. 1978-1987) 20E 4 1956 85/115 Benziner CIH 22E 4 2182 85/115 Benziner CIH H25E 6 2461 100/136 Benziner CIH 25E 6 2461 103/140 Benziner CIH 28H 6 2753 103/140 Benziner CIH 30H 6 2935 110/150 Benziner CIH 30E 6 2935 132/180 Benziner CIH C30NE 6 2935 115/156 Benziner CIH Omega A (Bj. 1987-1993) 18NV 4 1771 60/82 Benziner OHC 18SEH 4 1771 85/115 Benziner OHC 18SV 4 1771 66/90 Benziner OHC E18NVR 4 1771 65/88 Benziner OHC S18NV 4 1771 Benziner OHC 20SE 4 1984 90/122 Benziner OHC C20NE 4 1984 85/115 Benziner OHC C20NEJ 4 1984 73/99 Benziner OHC C20NEF 4 1984 74/100 Benziner OHC C24NE 4 2393 92/125 Benziner CIH C26NE 6 2594 110/150 Benziner CIH 30NE 6 2935 130/177 Benziner CIH C30LE 6 2935 115/156 Benziner CIH C30NE 6 2935 130/177 Benziner CIH C30SE 6 2935 150/204 Benziner DOHC C30SEJ 6 2935 147/200 Benziner DOHC C30XEI 6 2935 169/230 Benziner DOHC C36GET 6 3615 277/377 Benziner Turbo DOHC Omega B (Bj. 1994- ) 20SE 4 1998 85/115 Benziner OHC X20SE 4 1998 85/115 Benziner OHC X20XEV 4 1998 100/136 Benziner 1.4 - 2.2 Ecotec Y22XE 4 2198 Benziner 1.4 - 2.2 Ecotec Z22XE 4 2198 106/144 Benziner 1.4 - 2.2 Ecotec X25XE 6 2498 125/170 Benziner V6 Y26SE 6 2597 132/180 Benziner V6 X30XE 6 2962 155/210 Benziner V6 Y32SE 6 3175 160/218 Benziner V6 Rekord D / E (Bj. 1972-1986) 17N 4 1679 49/66 Benziner CIH 17S 4 1679 61/83 Benziner CIH 18N 4 1771 55/75 Benziner OHC 18S 4 1771 66/90 Benziner OHC C18NV 4 1771 74/100 Benziner OHC 19N 4 1875 55/75 Benziner CIH 19S 4 1875 66/90 Benziner CIH 19SH 4 1875 71/97 Benziner CIH 20N 4 1956 66/90 Benziner CIH 20S 4 1956 74/100 Benziner CIH 20E 4 1956 81/110 Benziner CIH 22E 4 2182 85/115 Benziner CIH Senator B (Bj. 1988-1994) 25NE 6 2461 103/140 Benziner CIH C26NE 6 2594 110/150 Benziner CIH 30NE 6 2935 130/177 Benziner CIH C30LE 6 2935 115/156 Benziner CIH C30NE 6 2935 130/177 Benziner CIH C30SE 6 2935 150/204 Benziner DOHC Sintra (Bj. 1997-1999) X22XE 4 2198 104/141 Benziner 1.4 - 2.2 Ecotec X30XE 6 2962 148/201 Benziner V6 Speedster (Bj. 2001- ) Z22SE 4 2198 108/147 Benziner 1.4 - 2.2 Ecotec Tigra (Bj. 1995- ) C14SEL 4 1389 Benziner 1.4 - 2.2 Ecotec X14XE 4 1389 66/90 Benziner 1.4 - 2.2 Ecotec C16SEL 4 1598 Benziner 1.4 - 2.2 Ecotec X16XE 4 1598 78/106 Benziner 1.4 - 2.2 Ecotec Vectra A (Bj. 1989-1995) 14NV 4 1389 Benziner OHC 16SV 4 1587 60/82 Benziner OHC E16NZ 4 1587 55/75 Benziner OHC C16NZ 4 1587 55/75 Benziner OHC X16SZ 4 1587 52/71 Benziner OHC C16LZ2 4 1587 Benziner OHC C16NZ2 4 1587 55/75 Benziner OHC 18SV 4 1771 66/90 Benziner OHC C18NZ 4 1771 66/90 Benziner OHC E18NVR 4 1771 65/88 Benziner OHC 20NE 4 1984 85/115 Benziner OHC C20NE 4 1984 85/115 Benziner OHC 20SEH 4 1984 95/130 Benziner OHC C20NEF 4 1984 74/100 Benziner OHC X20XEV 4 1984 100/136 Benziner 1.4 - 2.2 Ecotec 20XE 4 1984 110/150 Benziner DOHC C20XE 4 1984 110/150 Benziner DOHC C20LET 4 1984 150/204 Benziner Turbo DOHC C25XE 6 2498 125/170 Benziner V6 Vectra B (Bj. 1996- ) 16LZ2 4 1598 55/75 Benziner OHC X16SZR 4 1598 55/75 Benziner OHC X16XEL 4 1598 74/100 Benziner 1.4 - 2.2 Ecotec Y16XE 4 1598 Benziner 1.4 - 2.2 Ecotec Z16XE 4 1598 74/100 Benziner 1.4 - 2.2 Ecotec X18XE 4 1799 85/115 Benziner 1.4 - 2.2 Ecotec X18XE1 4 1796 85/115 Benziner 1.4 - 2.2 Ecotec Z18XE 4 1796 92/125 Benziner 1.4 - 2.2 Ecotec Z18XEL 4 1796 Benziner 1.4 - 2.2 Ecotec 20NEJ 4 1998 80/109 Benziner OHC C20SEL 4 1998 Benziner 1.4 - 2.2 Ecotec X20XEV 4 1998 100/136 Benziner 1.4 - 2.2 Ecotec C22SEL 4 2198 Benziner 1.4 - 2.2 Ecotec Z22SE 4 2198 108/147 Benziner 1.4 - 2.2 Ecotec X25XE 6 2498 125/170 Benziner V6 6 2498 143/195 Benziner V6 (Irmscher) Y26SE 6 2597 125/170 Benziner V6 Zafira (Bj. 1998- ) X12XE 4 1199 Benziner 1.4 - 2.2 Ecotec Z12XE 4 1199 Benziner 1.4 - 2.2 Ecotec X14XE 4 1389 Benziner 1.4 - 2.2 Ecotec Z14XE 4 1389 Benziner 1.4 - 2.2 Ecotec X16SZR 4 1598 Benziner OHC Z16SE 4 1598 Benziner 1.4 - 2.2 Ecotec C16SEL 4 1598 Benziner 1.4 - 2.2 Ecotec X16XEL 4 1598 74/100 Benziner 1.4 - 2.2 Ecotec Z16XE 4 1598 74/100 Benziner 1.4 - 2.2 Ecotec X18XE1 4 1796 85/115 Benziner 1.4 - 2.2 Ecotec Z18XE 4 1796 92/125 Benziner 1.4 - 2.2 Ecotec Z18XEL 4 1796 Benziner 1.4 - 2.2 Ecotec X20XER 4 1998 Benziner 1.4 - 2.2 Ecotec X20XEV 4 1998 Benziner 1.4 - 2.2 Ecotec Z20LET 4 1998 141/192 Benziner Turbo 1.4 - 2.2 Ecotec Z22SE 4 2198 108/147 Benziner 1.4 - 2.2 Ecotec Belki işine yarayan olur. (ç)alıntıdır.
__________________ Mesajı son düzenleyen Diesel kompressor : 25-06-2007 - 05:24 |
| Senior Member | Re: Opel motor kodları
Z16XE(yukarıda yok) ve 18SV az kahrımı çekmediler.
Mesaj: 5,134
Z16XE yukarda mevcut vectra idi sanırım araç ikinci vectra bölümünde var Ama astra h vectra c felan eksik son olanları bulamadım
Vectra-C işte benim dediğim. Sağol paylaşımın için.
Mesaj: 10,366
Teşekkür eder , opel ECU arıza kodlarının dökümünüde isteriz
Mesaj: 5,134
Kaptan cd leri varmış opellerin bulabilirsin paylaşırım.Çalıyom zaten alayını
Alakası yok ama Opel Vectra tanıtım cdsi var bende, isteyene vereblirim(2003 model, küçük olanlardan). ![]() 2003 model olan araba, küçük olan cd bu arada.
| by AT = Almancı Taner | Re: Opel motor kodları
eline sağlık
__________________ always AT by AT |
| www.otvyehayir.com Kayıt Tarihi: 24-05-2006 Şehir: İstanbul Otomobil: CBR1000RR Vectra Elegance
Mesaj: 40,440
| Re: Opel motor kodları Z16XE şu an benim kahrımı çekiyor
| Junior Member Kayıt Tarihi: 18-09-2006
Mesaj: 6
Teşekkürler paylaşımın için...
